Thinking about WC.
Nick_Leo
well i have about 250 right now and my grandparents just ordered me a e6850 and im planing on doing some overclocking. im thinking about putting together a water cooling system for it but i also need a new case cuz mines just to small and messy. i was thinkign about the p180 leaving me about 150 or so for wc is that enough? bassicaly im looking for a case and wc setup in my price range or am i just better off with a really good cpu cooler?
For 150 dollars, i suggest you are better of with air cooling. one of the top air cooling heatsink is Thermalright Ultra 120 Xtreme.
I don't want to start a huge arguement here, but you can build a fairly good WC system w/ only $150. If you look for parts in the F/S/T forums, you can get some parts for really cheap which will help your budget cost. I'm in the same situation right now and it's working ;)
Used Pump (MCP655) = 50$
Masterkleer tubing, yate loon fans, Tline (jab-tech.com) = 20$
Dtek Fuzion new/used = 50$
Double rad used FSFT = 20$
Totally possible.
