thinking about throwing away my generic psu
Krayzie135
right now im running the 400watt "icute" psu that came with my case and i just got an X800 XL and will be getting an ABIT AI7 and a 512 stick of crucial ballistix pc4000 ram and i dont want all my new stuff to blow up. so im thinking of getting a new psu. how much power do you guys think i will need:
P4 3.0GHz northwood
X800 XL
ABIT AI7
Ballistix 512MB PC4000 (getting anoter stick when i get more money)
1 HDD
1 Optical Drive
** I will be overclocking, if that makes a difference**
$52.50 & shipping [24-pin & 20-pin] > 3yr warranty<
XCLIO XClio 450BL ATX 450W
Hold-up Time >20ms at full load, nominal line
Efficiency > 70%
Output +3.3V@32A, +5V@30A, -5V@0.5A, +12V1@15A, +12V2@17A, -12V@0.3A, +5VSB@2A
Approvals UL, CUL, TUV, CB, VDE, FIMKO, DEMKO, NEMKO, SEMKO
http://www.newegg.com/Product/Product.asp?Item=N82E16817189003
Since you have a Northwood & are not OC'ing this should do it. ;)
$62.82 & shipping [24-pin & 20-pin] Modular > 3yr warranty
Antec SmartPower 2.0 SP-500 500W
+3.3V@32A, +5V@35A, +12V1@17A, +12V2@19A, -12V@0.3A, +5VSB@2A
http://www.costcentral.com/proddetail/Antec_SmartPower_20_SP_500/SP500/F09966/
If you want more room to grow, this will take you up & in to low-end SLI.
$79: Enermax 535W Whisper II EG565P-VE FMA V2.0 (nVidia SLI Certified)
http://www.gameve.com/gve/Store/ProductDetails.aspx?sku=PS-ENERMAX-535
All the way to highend SLI.
Well, not to beat a dead horse. Wattage doesn't have as much meaning as people think it does. You need a power supply with strong 12v rails that is good quality. Once those requirements are filled, I can tell you from experience and gauging by other peoples systems configured with similar power requirements to yours, 350=400Watts max is all you should need. Provided the power supply is good. Technically you could probably get away with a smaller 300Watt model, provided its a damn good PSU in terms of amperage and quality.
