Think Mobo died not sure
carblow12
I have just had my computer on and when i turn it off to check what COLOR MY CPU was, because i heard that if u have a GREEN AMD processor that there is no way on overclocking with out a pin, not even if u buy a nforce2 but mine was brown so mines not locked. So when i put my Heatsink back on, I press the Power button and it won't Boot. And on my comcast modem there's a PC light (the wire go from the modem to the ONBOARD Ethernet) and its not on . So if my motherboard didn't die what else could be the problem? THnx in advance ( i have a FIC AM37)
Did you try to overclock the processor a little too much. Check for burst or burnt capacitors. Ya never know :eek:
gotta ask, did you replug the power into the MB and wall, i mean, not that anyone could be that stupid... :cool: but it could be done
