Falkentyne
- Jul 19, 2000
Everyone has had 100% success flashing to V4. Even the bricked bad flashes were reflashable.
The only problems in that thread are the following:
1) people who flashed the compressed RAR file after renaming the RAR file to a bin (oops).
2) people who flashed the 0 byted incorrect file without merging with the raw firmware file. They were able to recover and reflash after powering the monitor off for 5 minutes. This was actually a common problem. They forgot to merge the files with the 2nd command.
3) people who were unable to find the i2c address for the benq. That was usually when they attached it to DVI on the master PC. They fixed that by (for some reason, it worked?) installing the monitor INF driver file from the CD in windows.
if you read the last 2 pages in the Linux thread, someone who wasn't even good at English and who was massively confused, was able to flash with the Ubuntu method
if you use Linux just follow my instructions and you'll be fine
http://forums.blurbusters.com/viewtopic.php?f=13&t=779&start=200
If you use the official Mstar ISP unit, use the V2 instructions on the main blur busters page That thread you were reading was for LINUX (Ubuntu). it was not for Mstar flashes. The mstar unit is the official firmware flasher for the hardware scaler in the monitor.
Ok, backlight bleed pictures:
no noticeable bleed.
Things get exaggerated if you are right next to the screen but if I go farther back, it looks great.
The glow on the sides is probably just color shift from being too close to the screen.
1) Blur reduction on @ 100 brightness.
2) blur reduction off @ 100 brightness, up close (trust me you don't want to use 100 brightness with BBR off. it's too bright).
That glow on the sides isn't backlight bleed. if I go across the room, the panel looks virtually perfect.
3) BBR off @ 20 brightness (up close)
4) BBR off at 100 brightness, across the room, zoomed in.
NO blacklight bleed at all
