Think I am ready to pull the plug...
Rafael
After doing some research I think I have picked the MB, CPU and Memory to upgrade my existing PC (listed in my sig).
MB: GIGABYTE GA-EP35-DS3R
CPU: E8400
Memory: G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000)
My primary use is gaming....Age Of Conan being the one I am getting next.
All from newegg.com
Based on what I have read...this should all work out of the box without requiring any Bios flash?
Not necessarily,
In order to achieve that memory speed with that CPU, you will need to OC.
I found out that Core 2 Duo's like a 1:1 Ratio between Ram and FSB,
So you need to OC the board FSB to 500Mhz, then you will be able to take advantage of the memory speeds listed.
That set WILL work out of the box. The motherboard will set the memory to its rated speed. You dont HAVE to set it 1:1. But save yourself some money and just buy standard 800mhz memory. The benefit of ddr2 1066 isnt worth enough to justify the cost. Personally i recommend crucial tracers.
My reasoning for picking that particular memory was to give me some working room for the future..and the price for that kit ($89) was not that much(about $10) more than the other 800mhz sets...at least from NewEgg.
Getting 800mhz is defiantly the way to go, and it will work..
But, to optimize the setup, you will still need to OC
The E8400 has an FSB of 1333.
So the Actual FSB will be 333.25mhz. With this said, 667mhz memory would be optimal at stock speeds.
With 800mhz memory, you will still need to OC to 400mhz FSB. Again this is for Optimal settings.
Core 2 Duos like the 1:1 ratio, and applications will not get increased performance if memory is not on a 1:1 ratio with fsb.
Veedubfreak is right, in that it will work fine if you don't set it to a 1:1 ratio. But, again, for OPTIMAL settings, you should OC the fsb.
Crucial Tracers would be a fine choice for PC6400 memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148180
For something cheaper, also check out,
OCZ Reaper HPC Edition 4GB (2 x 2GB) http://www.newegg.com/Product/Product.aspx?Item=N82E16820227267
Or if you are willing to settle for higher latency, try:
CORSAIR TWIN2X4096-6400C5 http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
As Far as choosing the 1000mhz memory of future expansion, it will depend on future CPU's and motherboards you are using.
Hmm...I guess I need more education because I definately misunderstanding things.
None of those are cheaper than:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231145
The reason they are more expensive, has to do the the lower latency, they have a 4-4-4-4-XX timings, versus the slower 5-5-5-5-XX timing.
Ah thanks,
I was getting confused when people saying "save some money"...and linking memory that was more expensive. =P
Yeah, you can find memory that is 800mhz for cheaper if your willing to settle for higher latency.
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
CORSAIR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
I know there only slightly cheaper, but a dollar saved is a dollar earned..right
So, what it comes down to is whether or not you want to satisfy the 1:1 ratio or just get something that works. It's really up to you.
Personally, I'd get the 800mhz and OC just a bit. I don't personally like to OC, but the C2D run so cool that I see no reason not to, and gain that bit of optimal performance.
