Things I blew up while overclocking!
MLF
Ok here is my little list! Lets see what the rest of you have destroyed.
Asus K8V 2x
MSI KT400 1x
Tbird 1400 1x
Athlon XP1800+ 1x
430 Antec True 1x
VNF3-250 1x
Pentium 166 1x
Zalman 7000Cu 1x
A64 3000+ 1x
120mm Fan 1x
Slot Blower 1x
250 Watt Psu 1x
MSI K7T-Pro 1x
Shuttle AK31 1x
AMD 1600+ 1x
K6-2 475 1x
K6-2 450 1x
Entire Compaq that mouse got in made nest and ate cables thus frying self! 1x
Ok Ok that one does not count!
1 Lucky Star cheapass athlon XP motherboard
1 brand new $400 9800pro a year ago
1 MSI 875P-Neo
1 cheapass power supply.
I learned from my mistakes ;)
Either you have too much $$ to spend and your having fun, or you don't know what your doing :p
Rad777
I am having fun, I work as a college student to support my hobby. Over the years I did several voltage mods and was always tinkering. The Athlons I killed after I upgraded by using my spare pc as a test bed. However I killed a combo that I RMA'ed to newegg because a fan header shorted. So that is where the K8V and the 3000+ came in. Also just recently I had my VNF3-250 at 310mhz HTT before it started to go haywire. Hopefully a new bios chip will fix it.
I have crapped out a cheap 30 dollar 550W PSU I got from svc
a 1.4 T-Bird.... wasn't overclocking just doing stupid things with it
almost messed up my Gigabyte GA-7VAX 1394 m0b0, for some reason it won't POST when my 9600 is in it but will with my GeForce3 just fine.... not a huge list but it is sure to grow
P-90
Some P2 (been a while)
R9500pro
R9700pro
R9800pro
6800GT
One Abit IC7G-Max2
Mostly gpu... they seem to be much more fragile :p
I've killed an XP1700+ JIUHB DLT3C
GA-7DPXDW+
2 120GB WD SE HDD's
powmax 500w PSU
2 Slot A Athlons (650 & 800)
2 ABIT KA7-100
MSI K7Pro (or whatever that board was)
an old WD 1.6GB HDD
some other small miscellaneous stuff i'm sure i'm forgetting...
i'm waiting for those 2 120GB HDD's and the GA-7DPXDW+ to come back from RMA so i can try again...all that wasn't really my fault, the Powmax took most of the system out...so now the case has a TrueControl 550...i learned from that mistake...
I guess I'm doing everything right in reguards to cooling because I have never burned anything out (unless it was intentional) to my knowledge due to overclocking. I have had componants die due to the crappy Florida power characteristics where I live. My UPS was one of my better investments. I did, however, intentionally destroy some hardware while working as a tech at Best Buy. ;)
:( RIP:
Maxtor 60 Gig HDD
3 CDRom drives including 1 burner
a couple NIC cards
3 Power Supplies
:) Purposely killed in the name of science:
Duron 800 Mhz
Unknown FIC mobo
An old Voodoo card
Numerous fans
Some Compaq/HP computers
Duron 600 @ 1000, didn't have the HSF on right (stupid mistake..)
ATI Radeon 9800 Pro (failed volt mod)
Well you must remember we all have dirrerent opinions of what are dangerous voltages. When I upgrade it means time to put the old system parts at high voltage, unless I have a friend who want them.
Three D. Marks said:
I plugged in a CD burner I took 1/2 apart and shocked myself once. Does that count?
Thank god I'm not the only one... lol. I plugged a cd-rw in while my computer was ON..... oops? *sparks fly* :eek: Just glad to still be with everyone.
I forgot 3 floopy drives up in smoke 2 shocked me, plus several old power supplys have given me a good jolt!
How did you fry the zalman, it sounds like a good story :D
I have killed:
FIC mobo
2x athlon xp 1600's
Crappy 350w PSU
i've killed a matrox millenium 2 (pos indeed..)
dissected some fans
a really old computer.. i kinda put a screwdriver into. that was fun.. hehehe
that's actually about it.. nothing really truely fried, other than the matrox, which was intentional
I had a fan connector go on the header the wrong way with only 2 of the three pins connected and in the wrong holes. It shorted the board and the Zalman started to smoke. It killed the board and the Zalman and the PSU. Luckily all were still under warranty.
Might be small but some are interesting.
TI-85 Calc, tried overclocking it based on what a website said :(
2x Epox 8RDA
MSI mb cant remember model
T-Bird 1.2
T-Bird 1.33
XP 1400
XP 1700
XP 2000
GF2 Ultra
GF 2 MX 400
Radeon 7000
9200 SE
Tornado Fan
Antec 330
Antec 400
Old Antec case, I got pissed off when I cut my finger on it and hit it by reflex.
While thanks guys fro making me feel a little better about frying 4 hard drives and 1 FDD.
Seagate 80gb 8mb PATA
Seagate 40gb PATA
Hitachi 80gb SATA
Hitachi 80gb SATA
All Killed yesterday at 4pm lol. It sucked, but I know got 1 36gb raptor paid 160 at frys with tax cause I needed it asap. I am thinking I might pick up another 36gb for 100 off newegg or maybe returning the 36gb and getting 74gb.
Things I have fried.... This in cludes OC and LAN Parties.
Gigabit 7VZ x1 /w 700+ Athlon
1300+ x4
1400+ x2
1700+ x1 (We got it to 2000mhz before it melted)
ASUS A7V8X x2
Abit KT7 x1
Abit KT7A - Raid x1
Random MSI board with no model lable. x1 Slot A
Slot A 800mhz Athlon
ASUS A7V333 x1
ASUS A7V8X x2
ASUS A7N8X -Delux x1
ASUS A7S333 x1
2000+ x1
That's all I can recall resently. I know I melted a 166mhz P1 MMX once. Don't ask. I was board.
After looking at the list compaired to mine. I see a nasty pattern. Almost every one has fried an MSI board.... That don't sound to healthy for MSI
Well, let's see...
One 166Mhz P1 MMX plus Motherboard
Two 366 Mhz Slot 1 Celerons
One PIII 500 Mhz Katmai
One AMD Athlon K7 Classic (700 Mhz, back then when the Athlon Just came out... I think the Processor was something like 800$) + Board
One GeForce 256 DDR
One AMD Athlon K7 700Mhz Thunderbird + Board
One AMD Athlon Thunderbird 1.0 Ghz
Three AMD Athlon Thunderbird 1.4 Ghz
One Geforce 2 GTS
One Athlon MP (couldn't wait to try out the new Palomino Core)
A few Asus Boards (A7V), a few Epox Boards (Socket A), one Abit and an MSI Board.
One Geforce 3 Ti 200
Two Intel 2.4As
One ATI 9700 Pro
One Abit IC7 MAX
One Abit IC7 MAX-3
One Vapochill PE
One Sapphire 9800 Pro AIW
One Intel 3.0B
I'm sure I forgott quite a lot of stuff.
Oh well, there go a few thousand bucks down the drain... none the less, this Hobby is FUN. :)
wow--money to burn--literally. I have only fried a couple psu's--oh and one oem mobo.
wow, this makes me feel better after killing my asus k8v se deluxe last weekend :p
MuadDib420
Athlon 64 3200+ (2.2ghz stock)
gigabyte k8n pro
512 mb kingston pc3200 ddr
80 gb western SATA
XFX 6800 GT (370/1)
11070 3dmark2003
Amatuer. Got mine to about 2.2ghz on stock cooling, around 45 idle, 55 load. :)
Killed one AMD T-Bird 900 mghz processor back in the day. I accidentally crushed the core moving it back and forth between systems. :(
Other than that I have been blessed thus far though I never really got into extreme overclocking....
4 K6-2s when I stated messing with water cooling...
one was cause I stuck it at 3.5v cause it worked fine at 3.4... forgot that at 3.5.. those boards on;y have single volatge and not dual...
one was cause I took the heatspeader off, siliconed the resistors, put the heatspreader back on, siliconed it, and then filled the air space under the heatspreader with water to try and get a better overclock.. worked for a while, but eventually some water got to the resistors.
one was cause my water-block came off the night after I installed it..
one was cause one of the hoses came loose and the pump pumped all the water on the floor at night.
1x ASUS P5A... the CPU socket messed up cause I put too much pressure on it.
1x Athlon socket A 1Ghz... tightened the Alpha heatsink down too much... butes CPU into 4 pieces.
1x Athlon 700 slot A... shorted the L2 cache out with my custom spacers...
1x XP 1800+... killed the bridges after multiple times of changing the multiplier
don't remember anything else...
lessee...
SEVERAL hard drives (ibm 40gb, 5-6 27gb WD, almost got my seagate 120gb as well... oops:p)
just recently killed a p2 HP Kayak workstation... dropped a screwdriver on the mobo by accident and now it gets a bios error... but it is a p2 so no big loss there
my palomino 2100+... chipped the core... couple too many shoddy waterblock installs with a NSFA (not safe for athlons) mounting setup
coupla motherboards... busted caps (not really ME killing them, but still... they died)
bout the same number of psus as motherboards above... same thing. 3-4 of them smoked to death.
a fan or three... not sure exactly how many...
damaged a radeon 9000 pro... bent it a bit, now it isn't really stable @ any clock speeds (i also chipped the core a bit on that too... don't ask how)
ummm.... anything else...
keyboard or two (spills, breakages in general)
an 8 port 10/100 switch
a few monitors (i think a 15, a 17 or three, and a 19... mebbe a 14 as well)
i've probably taken out some memory here and there... nothing recently though
i've had fun taking a sawblade to a few printers a few years ago... love that 'cutting PCB' smell... can't beat it.
oh yeah, and a 286 as well. probably can throw a 486 or 5 in there too... whee:)
Killed K6-2 by direct die cooling it, nasty corrosion on those resistors, not to mention nasty chips on the die (not due to directdie)
Oh also killed K5 when I tried cooling it with a stack of ice cubes, don't ask me how! :eek:
Also got confused with that stupid Asus slotket, the diagram is backwards, I put 3+ volts through my poor celeron instantly frying it.
WOW! I thought I hosed myself.... I just killed a 12.1'' LCD from my carputer project... :(
Wasted money on that and an inverter, now need an OPUS DC to DC PSU, $200 fucking bucks for 150 watts :rolleyes:
Then another $280 or so on a lilliput or other touch screen LCD.
i toasted a celeron 600 that could do 1035 and an abit slotket III. all because i put it in a motherboard i found to test it out.;
