Thin Watercooling Rads
The only ones that I've read, that were worth mentioning are from the Magicool Brand. The Elegant, and the slim.
Both are relatively 'slim'.
My questions are, where do people buy these? I've found the slim at a few places, but the elegant rev 2.0 is IMPOSSIBLE to find.
Last question:
Aside from the two named, what other thin radiators would you guys recommend? I've done a bit of researching, at least more than none, but I haven't found too much info.
THANKS
Swiftech rads, theyre 34mm thick and come in high fpi and low fpi depending on what fans you plan to use.
hey guys, thanks for the reply! I've been using skinee's review for research but I didn't know that they did an addition to that.
I'm going to rethink everything, but if I still decide on a thin rad,
Swiftech MCR-320-QP it is!
