Thin(ner) case fans?
c1001
Does anyone know of any 120mm fans that are thinner than 25mm? I am trying to avoid puttting the dremel to my new P180 to mount an intake fan on the bottom of the front panel.
All I did was mount a 80 on the front of the case. The screw holes match up to the screen holes, you might have to align it, but mine is almost dead center.
