wkearney99
- Sep 8, 2010
I've got a 4U 24-bay case that has a 1U redundant power supply setup in it. I may convert it to using a Norco 4U backpanel that I've got. But this would mean drilling for a number of motherboard standoffs (including some Xeon heat sinks). The current motherboard sits on a tray that's mounted above the 1U PSU setup.
The tray is fairly thick gauge and has bent edges along the left/right/front. I really don't want to get into sawing them off. Now, if I had a bandsaw with a metal blade, sure... but using a dremel on this much material isn't happening. I don't need it THAT bad to put up with changing THAT many broken cutoff wheels...
Yes, I realize I could kludge it with some plastic standoffs and a backing plate for the heatsinks. I may just go hillbilly on it, but I'd prefer to find a better way, if possible.
So, before I go down that road I'm curious if there's a generic sort of ATX motherboard tray out there. Does anyone make just a flat sheet of metal that's pre-drilled for the various ATX standard mounting points? Something with counter-sunk holes for attaching the standoffs. This would let me avoid putting a lot of holes in the case. No doubt with a few in the wrong places, of course). I've already dug through my graveyard of obsolete machines and don't have a suitable tray.
Along these lines, does anyone make a PDF of the ATX mounting holes? Or a printable template of them? This to save me from getting it wrong, several times...
