thin fans?
Thermite Paste
anyone know anywhere that sells thin 92 or 80mm fans? i need some for a casemod project
whoa thats expensive.
im not looking for something that thin, maybe a little les than 3/4 the thickness of a normal 80 mm fan. thanks for the info tho.
and maybe just a little bit cheaper too :p
thanks that site has some nice 60 and 70 mm fans for cheaper i will probably use those. by the way, whats a good CFM for the airflow?
