THIN 200 mm?
drpcphil
does anyone make a THIN 200 mm case fan im still struggling with my case and such i have it in another thread here FYI, thanks!
tunatime
Well...OK
How thin do you need it? If it's colse to fitting you might be able to shave the shroud down some?
VirtualMirage
Bitfenix makes 25mm thick 200mm fans. I believe it is their Spectre Pro lineup. I used to have one in my Corsair 250D case.
