These mobo's and 8700
You need to give a little more information.
I'm assuming your asking whether or not the Zalman 8700 fits on these boards. I believe it should fit on the Asus board as my 7700 (which is bigger than the 8700) just fine.
yes the zalman 8700, i wanna make sure that it will no hit the northbridge HS, i also wanna make sure that it will not over hang the top of the motherboard.
