Thermochill Question
NMFord
Hi guys,
What is the best way to go about modifying a chassis to fit the non standard fan spacing seen on the thermochill 120 series?
I have a number of different cases available to me, I just need to know the best method so I can choose the suitable chassis.
doesnt it come with a template? if so then find one where you can fit it and cut out the appropriate holes. if not, email them and ask for one. theyed probably send you one free. if this isnt the info yuo were looking for please clarify. :p
There are thermochill templates available ... google should find them.
Do you already have your Thermochill radiator? If not, you might want to consider getting one that has standard spacing - it will make it easier to change your system in the future. The Thermochill's are great radiators, but some of the other ones out are good as well.
Also, Thermochill is reportedly changing to standard spacing in the next few months.
