Thermaltake XaserIII v2000 Problem
xtreme09
Hey guys, I have a Thermaltake XaserIII v2000 case. I'm wondering if there's any way to remove the right side panel. I got this nut that keeps spinning while i try to unscrew the screw in it but i need to get to the otherside of the case so I can hold the nut down while i unscrew it. Driving me nuts here lol. Any advice will sure be appreciated!
Thanks
qbackin said:
STFU you never use a crowbar on a computer! Anyway the screw is strip'ed or the case is strip'ed, so the only thing i can think of is to drill out the holes.
try use a flat screw driver pry on the screw while you try to screw it out, or try use a plier to slowly pull and turn it counterclockwise to get it out.
Worst case, use dremel cut off the head of the screw and get the rest of the screw from the other side.
Or drill it out..
