ThermalTake Tsunami
microxp
I got my case and my mobo, but i don't know where to hook up the micro_sw connecter. my mobo is a asus a8n-e. i think the micro_sw is for the led in front of the case i'm not really sure because the guide that came with the case doesn't tell you anything much.
there are 4 small connectors coming from the front of the case
power-sw....power button
power led.... power on light
hdd led.... hard disk drive activity light
reset sw.... reset switch
the manual that came with the case wont tell you where to put them for that you will have to read the motherboard manual. if you dont have one check the asus website for info.
