Thermaltake Tsunami Dream
board2death986
At first i thoght this case seemed a little tacky but behind the mirror coat finish and the carefully placed from LED's it actually worked out pretty well for my system (posted in sig). here are some pix of it, still kind of in progress, working out the airflow of the fans and the wiring is still a mess.
does anyone out there also use this case? ive maybe seen it once or twice around the forums
I also have a TT Tsunami, in silver with window, awesome case but the window is a little to big you have almost no space to hide the unnecasery cables from your psu. But the stock cooling system is pretty good (got my case temp down with 10 degrees).
take off the other side of the case noth the window and behind the psu is a rectangle opening i moved all my unused psu wires back there. Also down lower is a hole the size of the bottom to the top of the case for wires. You should try that but you cant put it in a big ball it has to be somewhat flat or the side wont want to go. I just buched all my plugged in fans and front leds and put em behind the cages and the psu wires in that hole. good luck
*edit* and what is that orange fan doing up there is that a dangling blowhole?
I just bought this case. I haven't transferred my computer in to it yet. :)
I was gonna ask the same thing...how is that fan staying up there at the top and what is it doing there? :confused:
because of the wierd design of the psu, heat just vents wherever it dam likes, i had a spare fan and plopped it up there to move the stray heat towards the back, i had thought of removing the top USB/Firewire ports and modding a custom blowhole but in the end i didnt want to damage the case and thought it worked fine as is. It is using a unique new method of restraint i like to call gravity and pressure, works like a charm really.
I also have the same case, too bad the fans are so damn LOUD! What other fans do people use?
I have 2 no name 5 buck each 120 mm fans, they arn't to loud... and I also have a cooler master 80 mm fan twistie tied to the side holes.. I got this case from off of a display shelf for 45 bucks. No fans, no screws, no drive rails, just keys and a slightly dented case. It's bent a bit right over the PSU.
Stick a nice cold cathode tube down the front and it looks sweet.
only thing i've seen is a blowhole cut where that usb pod thing was on the top. I wanna do that sometime its just a matter of me turning off my comp for a day and doing it. Yeah only thing i've seen is that blowhole that i can think of. If you find somethen else lemme know i'd like to see it.
What I'd really like to do to it is custom make a 90mm fan grill, then paint the insides blue or black or something. I don't really want to do a top blowhole, though I might If I ever get a new system and end up water cooling. Has anyone done some drive stealthing mods with this case?
I just picked up this case, my question is will all the stuff in my sig work in this case and will it be cool enough?
Thanx in advance
my system runs really cool, 32c system and 38c cpu under load... and 32c is ambient temps right now. you should be fine.
" Great" this case looks bad ass
:D :D
