Thermaltake Tsunami case + H20
TheRapture
Anybody have one INSIDE the case? I am going to be doing something soon, just deciding on a kit or a custom picked parts deal....realistically only room for a single 120mm rad since I have 3 hard drives, but I can always get a new drive as well and run only 2 drives.
If ya got one of these cases watercooled show me some pics....
Well, if you're in for some heavy modding, you can do what I did, which resulted in fitting normal gear (mobo, hdd, dvd-r, etc), D5, and 120.2 rad inside the case. It requires the following:
totally disassemble and reconstruct case with back and mobo tray flipped to put psu at bottom -> building hdd rack (or put in unused 5 1/4 bay) -> poking holes in top -> mounting rad in top with fans on top.
It works well, although airflow is a bit screwed up.
If I were you and you don't want to hack up your case, I'd just use a radbox and hang a rad off of the back. It works fine, and is what I used to do. I just wanted a challenge.
