my antec neo power runs very hotDejaWiz said:in plus the dual fans on the Antec TruePower psu to exhaust it.
fenderltd said:Post your system up. This case runs a little hotter than my Lian Li did . I dont have the rear exhaust fan in mine as I have my radiator mounted their but the temps are too awfull bad. I would say if your using a stock HSF pick up a thermalright XP90 model with a nice panaflo fan for around 40 shipped and you will be amazed. www.svc.com has the Thermalright XP-90 for 24.99 which is a steal.. I just tried buying one for a back up because I plan on selling my W/C setup for something else and its OUT of Stock! Damn them! The best of the best is the Thermalright XP-120 but with some cases mobos can have mounting trouble. A lot of guys use the Thermalright Si-97's and XP-90c (c= copper) The temp with my Thermalright Si-97 is so damn close to being the same as my w/c setup but after load the w/c cools down quicker.
If you know all this and want me to shut up press 1 now![]()
Z(+)DIAC said:You sure it's still not being offered in-store?
Unfortunately, they can not be daisy-chained into a single controller.Shmuckety said:Do you have these? Do they plug in to each other and can I use only one manual fan controller for all of them or not use it at all?
These look cool, I may just get them.
