I do have XFX 600 right now but I'm suspecting that it might be the source of crash so I'm switching out.think your better of with a evga or xfx unite even if it a slightly lower wattage
Better is to give 10 $ more and take the EVGA Supernova G2 850 http://www.amazon.com/EVGA-SuperNOV...8090588&sr=8-1&keywords=evga+supernova+850+g2
or 20$ more and get the Corsair RMi 850 http://www.newegg.com/Product/Produ...8&cm_re=corsair_rm850i-_-17-139-138-_-Product (*surprisingly, the RMi 850 is currently cheaper than the RMx 850, although it's a little better in build quality and has digital monitoring as well)
All 3 PSUs, G2 , RMi, RMx, combine excellent performance/build quality, in a very low price as well![]()
EDIT: I didn't notice that the Tt you want is priced with 80$ after rebate. I judged it with its normal price, 110$ at newegg.
Can you explain what you mean by "check JG first" I'm not familiar with the term.When you're looking for an EVGA just make sure to check JG first. At first when I saw EVGA I was worried if a review was done but then I saw Sith'ari linked to one for the TT unit. Checked out the review for the one he suggested and it's basically a flawless PSU.
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=377
Since EVGA is just rebadging things make sure you look for the exact PSU. I was looking at ones in the <600W range and the #1 selling unit on Amazon doesn't get all that favorable of a review. http://www.jonnyguru.com/modules.php?name=NDReviews&file=print&reid=384
Or even the G1 of the 650W super nova isn't as good as that G2 850W. http://www.jonnyguru.com/modules.php?name=NDReviews&file=print&reid=442
Thermaltake in my opinion make great cases, but PSU's and wc avoid them like the plague.
I be the first to admit..my current thermaltake has been flawless....perfect rails and stability. I just really think if i were buying today there's better out there![]()
