The S1283 weighs more because its a bigger HS and in turn has more surface area for cooling, I grantee you the TMG i1 is NOT going to be quieter than the S1283, just because the manufacture claims a sound level does not mean you will get that, and Thermaltake is known for lying about sound levels on their fans, I know, I have a few of them. Also that 16 dBA rating it has is going to be for when its at the minimal 300rpm NOT the upper range of the 2500rpm fan. The 120mm fan on the s1283 is going to move more air at a lower sound level than the 92mm fan on the TMG.
I've had an arctic cooling freezer 7 pro with an e8400 and that cooler was very silent, i was satisfied with it, i just don't buy it again because i can mount that cooler only in one position in my board, and i see thermaltake tmg i1 is the same type of cooler, but i see that i also have the xigmatek s963, in the same range of price, what can you say about it?
