Thermaltake SilentCat?
Jap1987
I was looking into getting two more 90mm fans for the sdes of my case and also replacing the 80mm on my heatsink seing how it is summer now and 21cfm just isnt enough cooling. My question is the connectors are 3 pings on the SilentCats is it ok to run 3 of these off of my motherboard? Or will that cause a problem? Also my powersupply is an enermax whisper 475 watt.
They should be fine, they dont use much power
Fans like those don't draw very much power. There are always some exceptions to that rule.
By the way, that 21dBA rating is false.
It may be false but telling me what they are rated for might have been more helpful, thanks for all the input.
