i'm planning on purchasing this http://www.newegg.com/app/ViewProductDesc.asp?description=35-106-036&depa=1 hsf for my amd 64 3200+ which currently has the stock hsf attached to it. anyways i was just wondering what should i expect when i install it. will i have to replace the backplate or is the stock one the correct size? amd are there any precautionary measures i should take after removing the old hsf and placing this one in? any other tips or advice is surely welcome.
