thermaltake shark case
uberdude said:
any opinions before i drop the cash on teh bad boy?
Not my cup of hot chocolate, but if you like it go for it. I do like some of the features that it has, removable mobo tray, dual fans front and back, it can fit a watercooling system also, so you can go that route anytime you want.
And you have to love that harddrive system that it has.
If you like it, go for it. Simple as that.
I would say only if you want to watercool, otherwise there's a lot of other well-made cases for air-cooling
and of course if you like that crazy "body kit" on it.
I think you could get a better quality case from Cooler Master or Lian-Li for the same price. It would look better too.
inside its great
outside Bleh!
call it personal opinion but a tad bit too flashy, although i do like the mesh
A major problem with that case (which the linked review mentions) is that the front ventilation is pretty much nil. That makes the front fan useful as only a noise maker, and it severely degrades the hard drive cooling. Ignoreing the asthetics (which are iffy to begin with) this fact alone is a deal breaker for me. I'd say pass
