Thermaltake Mozart TX Worklog
fadz
Well this is the start of my Thermaltake Mozart TX Build to all be run with watercooling,case will be resprayed in a Gold colour with a blue light theme to it in the interior,interior will be resprayed black,side case window will be cut and fit with one big clear sheet of perspex,rather then the stock side window i have currently.
it will be running the following specs:
Cpu:Q6700
Mobo: DFI Lan Party x48
Ram:Corsair XMS2 pc8500(1066mhz) 2x2gb
Gpu:Gigabyte 9800gx2
Psu:Gigabyte Odin 800W
Case:Thermaltake Mozart TX
HDD's:2x150gb WD Raptors + 1x320gig seagate barracuda
DVD Drives:1x Pioneer BDR-202BK Blu-ray read/writer 1xPioneer DVR 215bk read/writer
Fan controllers:Scythe kama metre x 2
Watercooling setup will consist of:Fuzion v2 CPU BLOCK,GPU Block EK-FC9800 GX2 SLI - Acetal,Pump MCP655 12v (Laing D5 Vario),Rads 1x RS240 UV Blue and 1 x RS120 UV Blue,all gear is currently ordered and waiting to arrive from Flabbergast,il add along as it all comes,any questions ask away,pics below:thumbup:
CURRENTLY WAITING ON: *Watercooling GEAR,*Blu ray dvd Drive/Writer
I will be running the watercooling setup under the following diagram provided by DavLe.BeRRy(id also like to request an approval of the Loop layout,is it the best way to go with the watercooling gear il be running?)
DFI Lan Party x48
Gigabyte 9800gx2
Q6700GO Cpu
Fans- 10 x 120mm Antec TriCool BLUE LED + 1x 80mm Antec TriCool BLUE LED
Hdd's - 2X150GB WD Raptors + 1xSeagate barracuda 320gb
Gigabyte ODIN 800w PSU
Dvd/blu ray drives
sounds great! looking forward to seeing more, its such a huge case... lol with that many led fans, you will be able to see it from space!!
lol ye,blue lighting has always been my theme,waiting on some blue ccfl tubes to,so its going to be Hell Bright:p
*UPDATE* 14/5/08
Here comes the ram
And a quick update of the perspex removed off the side panels,should be cut to the new shape tomorow
how are liking your dominator fan? had it myself and thought it was too loud for the amount of air it pushed which was close to nothing - other then that it everything looks like a good start -
Dominator fan=SOLD lol after my last experience with one in my previous machine thought id have to sell this one,seeing its irrilevant.
*UPDATE* 19/5/08
So finally got the kama meter fan controllers x2,to run all these dam fans and the UV blue cabling KIT,pics below
And the side panels with some re mods,perspex arrived to but is currently sitting away until the case gets sprayed ofcourse;)
Where did you buy your Mozart case from?
I've been checking around and trying to find the best place...
