Has anyone upgraded the radiator that came with the subject system, and kept it internal?
I'm having trouble finding a copper rad that matches the dimensions of my current rad 120x240x40 mm, and seeing that I had a heck of a time getting that one in place I'm not sure if I can go with a different size. The current rad with side mounts attached is 150 mm wide and it looks like I should be able to go as high as 250mm without interference, and the depth is 45 mm's with the fans attached.
When you buy a rad such as HW's does it come with side mounting rails, so as to attach to the case or can you at least buy side mounting rails?
All my drive bays are full right now and can not get away with less than six HD's, so I can't go any deeper.
I'm trying to get away with ordering parts without ripping my system apart to see if I could modify the case to take a larger rad.
I appreciate your input.
Thank You
Thank You
