Thermaltake Core X2 Case Noise
obviouslytom
Extremely [H]
Just picked up the Thermaltake Core X2 case since I wanted a bigger case than what I previously had. I am experiencing one problem with it and its some vibration nose coming from the front right of the case. If I remove the front, and push in on the metal, the noise goes away.
Does anyone know what I can do to stop this? I have tightened down every exterior screw I can find and even the fan screws that are on the front thinking that caused it, but it didnt work.
