I have been thinking about getting the thermaltake so I could push my overclock on my Gainward geforce4 ti4200 a bit higher and the fan is noisy..
According to the specs.. its about 30dB how loud is that in comparison to a stock fan? Overall it seems okay but im concerned about the noise... (I like the $13 price tag though cheaper than the zalman or the tt giant2)
Oh yah.. and the mounting.. do you know if it will fit on all Geforce4 cards? I know mine has two holes that are further apart for the stock gainward cooler and a second set of holes that are closer to the gpu.
And since it uses a three pin connector, can I unclip it from the current fan connector and wire it to my card and avoid running a extra wire to my card?
