I can't find a single review proving the dock's SATA II capabilities.
Can someone with one, simply pop in a known SATA II drive they have, and test in HD Tach / HD Tune and look at burst speeds (the only measure that should be capable of going over 150mb/s).
You should also do the same test out of the dock, just to make sure the bursts for sure are over 150mb/s normally.
Either the bursts should be the same in/out of dock, OR they'd be capped under 150mb/s in the dock, it it's not SATA II capable.
