Thermaltake Armor question
xerus`
The top blowhole fan, and the small fan on the top back are supposively 90 x 90 x 25mm, and I dont think I can find any 90mm fans to buy. Will 92mm fans fit into the slots instead of a 90mm fan?
If a 92mm fan will fit, does anyone know if 92mm fans with UV cold cathodes on them exist? Thanks ;D!
Yeah, they mean 92mm. I assume you dont have the case already, so I'll tell you: it already comes with the fans. Quite a few of them. As far as UV cold cathodes, probably not. UV LEDs... maybe. Not sure if one can even have UV LEDs. But I'm almost certain you can't get fans with cold cathodes on them, just cause it would be so ridiculous.
I know that sunbeam makes fans with LEDs in them, but I think they're only 80s... Guess I'll have to stick with the black and orange fan for now then ;(
Several manufacturers make 92 mm led fans, and i think thermaltake has a few uv led ones.
As for cc 92mm's i could not find any
