Thermaltake Armor Full Tower help
AliceCooper
Ok so i get all my computer parts tomorrow and i hear that the tooless deign that thermaltake uses sux for big video cards so is there any special way to take that off like in snap it from the rest of the case or are there screws?
It may be hard from the pics, but the pci slot covers are held in by tension and one end is hooked into the hole where you normally screw down any daughter cards. So yes you can screw in your video card normally.
