Thermaltake Armor A30 Mini Tower Case
HardOCP News
[H] News
The TechSpot crew just put the finishing touches on a review of the Thermaltake Armor A30. The review says that the case is intended for gamers, not HTPC user (something about it belonging in the batcave), but I think it would be fine as either or / both. What do you think?
Most mini towers claim to be designed with both gaming and HTPC use in mind, but the Thermaltake Armor A30 makes no such promise. Instead, it is strictly a gaming chassis designed for LAN party goers. We feel gamers will be attracted to the Armor A30's near shoebox-sized design that can accommodate high-end hardware such as the AMD Radeon HD 5970, today's largest consumer graphics card.
I think it looks pretty cool, but I see what they mean about the HTPC thing. The TV is supposed to stick out, other stuff should be sleek and minimal and out of the way if possible.
While I've not been a fan of small form/slim/mini tower PCs for home use (had one, the heat issues were ridiculous), this case makes me wish I knew how to build.
At 56, disabled (one of which is nerve damage from my right hand all the way to my elbow) learning to build isn't going to happen.
I really, really like it! The size is great, there is what appears to be good ventilation and after looking at the dimensions, I have a shelf near my computer desk it would sit perfectly on - out of range of the kitten in the house. And the weight. My current computer weighs over 40 lbs. Have it on what was an ikea pine shelving unit that I attached wheels to so I can move it around.
It's nice that Thermaltake left out all the plastic they usually build cases with. I like it.
You must have missed the Xaser III (2002), and VI (2008, and still in production).
This case looks like it could be a great HTPC case, looks like a squished down V9 case.
Everything I bought from Thermaltake has been flashy crap, until I bought a Lanbox Lite for someone else's computer I was building because it was inexpensive. I love the Lanbox Lite and this case looks like the same layout. I would have bought another Lanbox Lite for my HTPC, but the use ports are on the side and it didn't work well for my receivers. Not enough room on the side and worse reception.
This case looks like it would be good for a HTPC. I would replace the fans with something that didn't have LEDs. I would probably glue something over the power light so the reflection shined down. One of the things I like about this one over the Lanbox lite is the fan on top. I don't like the window or other flashy crap. I would paint the silver Thermaltake badge in the front and plug the blue USB if I wasn't going to use it. After those few minor mods, the case is an excellent HTPC case.
Also motherboard with horizontal SATA ports are harder with Lanbox Lite and probably this case. I fit mine in no problem, but if i was gonna get another motherboard; I would get one with vertical SATA ports.
I will probably buy one when I don't feel lazy.
Looks to me to be just a LanBox Lite with new clothes. But.. that being said I really like it. I've owned a Lanbox lite and i thought it was a pretty good case. As I imagine this one is. It's being put on my short list for mATX cases and bumping the LanBox Lite off.
