no, it isn't MUCH better. that's a common misconception. if you apply either one well, the temps that you get will be within a degree or so.Anime_Fan said:Its just your average paste it would get the job done for a stock speed user or a mild oc situation. AS 5 is much better![]()
DFI Daishi said:no, it isn't MUCH better. that's a common misconception. if you apply either one well, the temps that you get will be within a degree or so.
don't get me wrong, i use AS5 and ceramique myself, but there is no REAL reason not to use the stock thermal paste. the white goop works just fine.
i think that most people who talk about massive temp drops when going over to AS5 are mistaking the large improvement that proper application makes, combined with the marginal benifits of a better thermal compound, for an improvement in the thermal compound alone.
Klync said:Thanks for the quick reply. Man, I still using AS3(old school). I probably getting me a tube of AS5 on my next order. So, either way, the Thermalright thermal paste should be sufficent for none over clocker, I say?
yeah, it all makes a difference, but not a few degrees: it's less than that even, when well applied.Anime_Fan said:Hehe much better is probably an exageration when talking about thermal pasteI would definately agree that using as 5 typically provides a couple degree diff
But it all makes a difference
DFI Daishi said:yeah, it all makes a difference, but not a few degrees: it's less than that even, when well applied.
put simply, toothpaste, vegemite, mineral oil, stock thermal paste and AS products perform close enough to one another that your CPU diode can't consistently tell the difference between them, all other things being equal: there is no reason not to use stock paste, even when you are OCing, if that is what you have handy while you are putting things together.
now, i don't mind paying a few bucks extra to have the best vs brand X thermal paste, so i buy and use AS when i am purchasing. if i run out during a build: no reason to sweat it, just use the stock paste i have hanging around, and pick up a tube to re-apply with later.
Emission said:Exactly, I had a spare tube of Dynex laying around and im out of the good stuff so I slapped some of that on. I get great temps regardless of the paste. Its kind of hard to tell when its worth $10-20 more for 1-3C less in temps. You should see the stuff they apply to the IHS's of processors. its got so much metal in it its practically solid. Now THATS what we need lol.
intel permanently bonds the core to the IHS using an indium based solder. it's pretty solid.r_a_s88 said:what i was thinking...would brazing a heatsink to the IHS be feasible? i would imagine it'd seal better than any TIM, albeit permanently. why hasn't it be done, other than it being insanely hard to braze materials together?
