Thermalright True Spirit 140 Direct CPU Air Cooler @ [H]
Discussion in 'Overclocking & Cooling' started by Kyle_Bennett, Apr 19, 2017.
  1. Kyle_Bennett
    Kyle_Bennett El Chingón Staff Member
    48,679
    May 18, 1997
    Thermalright True Spirit 140 Direct CPU Air Cooler - Thermalright has been laying low in North America for the last few years, actually almost 5 years the way we see it. The True Spirit 120 was an inexpensive Titan when it came to cooling hot CPUs. Thermalright's legacy is extended today with the True Spirit 140 Direct, but is it worthy of the "True Spirit" name and most importantly your hard earned dollar?
    Rvenger and Bees like this.
  2. RAutrey
    RAutrey [H]ard|Gawd
    1,559
    Jul 25, 2002
    Hey Kyle. I see that AM4 is not listed under AMD compatibility but you used it in your Ryzen testing. Was that on a CH6 MB?
  3. Kyle_Bennett
    48,679
    May 18, 1997
    The True Spirit 140 Direct comes out of the box with AM4 support. It was actually what I used as a template to dill all our custom backplates for Ryzen testing before any of that information was out. Thanks for the heads up. Compatibility specs are fixed. :)
    RAutrey likes this.
  4. Rvenger
    Rvenger [H]ard|Gawd
    1,259
    Sep 12, 2012
    I literally bought this an hour ago and didn't see this review yet :)
    I'm glad I bought it because my H110i started sounding like an old 7200 RPM Maxtor with a bad bearing. Throwing in the towel on the AIOs. I found this on ebay if anyone wants to match up your build theme with a white accent fan... or push and pull - http://www.ebay.com/itm/201507847891
  5. Bees
    Bees [H]ard|Gawd
    1,095
    Jul 24, 2011
    With recent HSFs performing at near or even better temperatures than some AIO units, would have to agree. Was in a similar boat as you, except I had an H100i and found a slightly overpriced FUMA that still had a better price-to-performance ratio than everything available on the market. During the waiting period of that FUMA shipment from overseas, the Intel stock fan was installed in my system and didn't realize how much noise I had gotten used to with the AIO over the years. I recall that being a selling point of the AIOs - not only better at dissipating heat, but quieter performance than potential high RPM fans installed on a third-party cooler. Apparently improved design in surface area has reached a newer level. Of course, the units still have their place in smaller configuration PCs, but if you can fit a moderate-to-large air cooler in your system and do a bit of research, air is back, and it doesn't need to be BIG to perform admirably.
    Glad to see such a popular HSF gain a worthwhile successor.
  6. Rvenger
    Rvenger [H]ard|Gawd
    1,259
    Sep 12, 2012
    The AM4 support sold me on this one. Such a pain to contact the manufacturer and hope they snail mail you a bracket. Phanteks did a good job on my cousin's ph-tc12dx and it arrived in a little over a week but they should be included by now you would think or at least readily accessible for a very small cost at the e-tailers..
  7. psyclist
    psyclist Gawd
    709
    Jan 25, 2005
    Still rockin the OG TRUE120 in my HTPC, started out cooling my Q6600 back in 2007. 10 solid years, still great temps!
  8. daringx
    daringx n00bie
    11
    Apr 13, 2017
    I'm a bit confused by the heat pipe design on these types of coolers. It's my understanding that heat pipes work best when oriented either in-line with or perpendicular to gravity (i.e. hot air/coolant naturally rises relative to gravity). In this and many other cooler designs installed in a typical tower case, I see that half the heat pipes are oriented above the heat source and the other half below. I would expect this orientation drastically reduces the cooling potential of the lower half heat pipes because they are trying to conduct heat away from the CPU against gravity.
    I would think better performance could be gained if the cooler was rotated 90 degrees so that the heat pipes were perpendicular with gravity and the fans forced the hot air up through the top of the case. Additionally, since hot air naturally rises this seems optimal from a thermal efficiency point of view.
    Has any experimentation to this effect been documented? Or are heat pipes these days so efficient (such as using embedded wicking materials) that actual orientation relative to gravity has little consequence?
    Virtual_Bomber and AceGoober like this.
  9. Kyle_Bennett
    48,679
    May 18, 1997
    I honestly do not have the environment or equipment here to measure that sort of delta, or what I think the delta would be, but let me ask Thermaltake, and share your post, and see what feedback we get.
    BlueFireIce and Virtual_Bomber like this.
  10. Dave65
    Dave65 Gawd
    602
    Nov 30, 2006
    Damn, this is pretty close to AIO cooling, for the money it seems like a great buy.
  11. Olle P
    Olle P Limp Gawd
    252
    Mar 29, 2010
    Does it require the included backplate, or can it just use the mountings provided with all AM4 boards?
    (Thermalright's online manual doesn't include instructions for AM4.)
    I suppose some effect by orientation does exist, but it's neither "drastic" (a few degrees at most) nor because "they are trying to conduct heat... against gravity".
    * Pushing "heat" against gravity is a non issue since the steam will expand to fill the entire tube. (This is thermodynamically driven water cooling, you know.)
    * The issue is to make the condensed water run back up to the hot spot, which is managed through a wick.
    Horizontal heat pipes are slightly better, yes, provided that it doesn't disturb the general air flow direction through the case.
    Natural convection (at these temperature gradients) is at least a magnitude smaller than the power of any fan, so it's not a factor.
    The very best orientation is to have the motherboard horizontal and the pipes pointing up. That way the condensed water will easily fall down to the hot spot.
    primetime likes this.
  12. RAutrey
    RAutrey [H]ard|Gawd
    1,559
    Jul 25, 2002
    Just got mine on order. Tell the boys at amazon Kyle sold another one.
    Kyle_Bennett likes this.
  13. Pusher of Buttons
    Pusher of Buttons [H]ardness Supreme
    5,005
    Dec 6, 2016
    Nice. My first enthusiast build was an Athlon with a Thermalright giant hunk of copper and Delta fan....perhaps this will pair up nicely with this summer's Ryzen build.
    With the Ryzen OC tests, have you noticed the coolers being much of a bottleneck since the 4ghz mark seems to be a pretty hard and fast barrier regardless?
  14. Skylinestar
    Skylinestar Limp Gawd
    295
    Jun 14, 2011
    What's the best way of applying the TIM? Apply a pea size TIM on the HDT base, scrap with a card, then apply a pea size TIM on the CPU, and finally install?
  15. britjh22
    britjh22 Limp Gawd
    342
    Oct 15, 2014
    Have you guys considered changing the test bench to include a larger processor like X79/X99 or AM4 (I actually don't know if they have a larger heatspreader than LGA 115x), or just do a comparison. I wonder if the small heat spreader and the relatively bad TIM in the non Devil's Canyon processors is causing a bottleneck for the bigger air coolers where they can't really stretch their legs.
  16. Shotglass01
    Shotglass01 [H]ard|Gawd
    1,815
    Aug 26, 2005
    Picked this up in early in the year for my 7700k. It's a great cooler. I also like the plastic shim they provide to add extra strength for socket 1151 chips known to have a little weaker PCB. Great review!
  17. DuronBurgerMan
    DuronBurgerMan Gawd
    633
    Mar 13, 2017
    A quick question, Kyle.
    I picked up the Noctua U12S for my Ryzen build. Not sure if you've tested that before, but if so, how does it compare? I'm curious because you said you used the True Spirit in your Ryzen OCs, and I'm wondering if the performance of my cooler ought to be comparable.
  18. Quartz-1
    Quartz-1 [H]ardness Supreme
    4,331
    May 20, 2011
    I noticed the be quiet Dark Rock Pro 3 in the noise chart but not in any of the others. Could you add it back in? Are they all otherwise consistent?
  19. Quartz-1
    4,331
    May 20, 2011
    They should know if you used the referrer link from [H]. Unfortunately it doesn't (apparently) work from the UK.
  20. RAutrey
    RAutrey [H]ard|Gawd
    1,559
    Jul 25, 2002
    Yep used the link.
  21. Rvenger
    Rvenger [H]ard|Gawd
    1,259
    Sep 12, 2012
    Kyle_Bennett , how difficult is the fan clips on this model? The original true spirit 140 I had was next to impossible to get the fan to clip on.
  22. Kyle_Bennett
    48,679
    May 18, 1997
    There is an included backplate. The mounting system does not use the stock AM4 backplate.
    With these direct-touch heatpipes, you NEED to spread out your paste thinly and evenly across the face of the IHS to be sure you get even coverage.
    I used the Noctua U12S a lot during my Ryzen testing as well. I do not think you would see a lot of differences in these coolers, but I have not specifically tested that. Also, the Noctua I used had a 2000RPM Industrial fan on it, so they are quite a bit different in sound profile.
    The fan clips are one of the things I do not really like about the cooler. Make sure you have the little rubber bumpers installed before mounting the fan. The clip system is a tiny bit cumbersome, but still not a deal breaker. And lets face it, you only deal with those once since the fan is not in the way of the RAM.
    DuronBurgerMan likes this.
  23. pgaster
    pgaster [H]ard|Gawd
    1,189
    May 17, 2008
    I read a few reviews here and there for this and somebody said that AM4 compatibility started in around January or so.
    Some after this got back plates with the AM3 and AM4 holes, but received a plastic insulator for between the bracket and motherboard that only had the AM3 holes. They had to use the backplate as a template to drill the AM4 holes, or one guy heated up a screwdriver and melted the holes. Maybe by now all shipping units have the plastic insulator with both the AM3 and AM4 holes, but just wanted to mention what I read.
  24. AlderaaN
    AlderaaN [H]Lite
    89
    Oct 21, 2005
  25. Kyle_Bennett
    48,679
    May 18, 1997
    I just pulled the one out I have here and eyeballed it on a mobo currently on the test bench, and no it does not push over the socket-side edge of the PCie x1 slot on this board. GBT Z270 Gaming Ultra.
    AlderaaN likes this.
  26. AlderaaN
    AlderaaN [H]Lite
    89
    Oct 21, 2005
    Thanks for taking the time to check it out, Kyle.
    Just to confirm, if I was to populate the first PCIx1 slot with a Sound Blaster card, like so:
    [​IMG]
    said cooler won't interfere with it due to its width (at least not on GB GA-Z270X-Ultra Gaming board)?
    Regards,
    [​IMG]
  27. Napoleon
    Napoleon Gawd
    961
    Jan 27, 2003
    nice, I think I'll use one of these to replace my buddy's dead HSF and revamp his gaming comp. I love the compatibility options
  28. Kyle_Bennett
    48,679
    May 18, 1997
    No the cooler should not interfere. Basically what you are talking about is whether or not it violates PCIe spec, and it seems to not violate that space.
  29. SeymourGore
    SeymourGore 2[H]4U
    2,192
    Dec 12, 2008
    I've been using a AIO for the past couple of years - but there's a certain dignified beauty about an air cooler.
    Thanks for the AM4 blurb (how it performed well during your Ryzen testing) at the end of the review. I was itching to whine here in the forum about it, but you had it covered.
  30. ashmelev75
    ashmelev75 [H]ard|Gawd
    1,480
    Nov 29, 2007
    How does it compare to good 'ol Cooler Master 212?
  31. Trimlock
    Trimlock [H]ardForum Junkie
    14,521
    Sep 23, 2005
    I still chose AIO's to act as my cases primary fans and to make it easier to navigate my case.
    If these came out a while ago before I bought my Fuma, I'd rather have this.
  32. ssnyder28
    ssnyder28 2[H]4U
    2,626
    May 9, 2012
    Nice review. I was gonna go grab one off amazon but they aren't available :/.
  33. Napoleon
    Napoleon Gawd
    961
    Jan 27, 2003
    Yea there were 2 yesterday and now they're gone. Crap! I was going to buy one as well
  34. xorbe
    xorbe [H]ardness Supreme
    5,780
    Sep 26, 2008
    Wow nice HSF results
  35. sirmonkey1985
    sirmonkey1985 [H]ard|DCer of the Month - July 2010
    19,803
    Sep 13, 2008
    yeah i've been checking back periodically still haven't seen them relisted.. trying to hold out hoping they do so i can pick one up for my new build otherwise i need to figure out an alternative since 240mm AOI coolers aren't an option for me.
  36. fwiler1
    fwiler1 n00bie
    34
    Feb 14, 2016
    Arrgghh. Needed a new cooler and narrowed it down to this and Fuma.
    Neither one available.
  37. Kyle_Bennett
    48,679
    May 18, 1997
    I pulled out an X99A motherboard this weekend and it DID encroach on the 1st PCIe slot. And I immediately started thinking about this thread. I reached out to Thermalright on this, and they did explain to me that the TrueSpirit 140 Direct DOES NOT inside PCIe specifications. That said, I had no issues with it on other motherboards. BUT, not all motherboards put the 1st slot right up to the PCIe spec limit. The board I found the issue with was an MSI X99A Godlike Gaming and had four x16 PCIe slots....so jammed packed. Here are the measurements.....and the fan mount wires add a couple mm to this.
    Flogger23m likes this.
  38. Napoleon
    Napoleon Gawd
    961
    Jan 27, 2003
    [H]orde- Just FYI, these are in stock and on sale for $39.99 at Newegg through next Monday 5/22
    Interesting, I still hope this is an option on mainstream boards, good to know the measurements to look for
  39. Napoleon
    Napoleon Gawd
    961
    Jan 27, 2003
