- Jan 15, 2005
if i were to get the true 120, and one of the scythe ultra-kaze 3000rpm fan, would the 38mm depth fan be able to work with the retention clips?
or if i were to get one of those IFX-14's will a 38mm fan work?
specifically this fan: http://www.newegg.com/Product/Product.aspx?Item=N82E16835185054
or maybe this fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185060
seems to have a lower CFM to noise ratio.
edit: found out that the ifx-14 will support a 38mm fan.
where's a good place to buy one for less than $80?
or maybe this fan
