Thermalright Silver Arrow vs Megahalems?
Dirtbag
So, now that I'm set on a motherboard, I want to re-consider the choice of my cooling solution.
Basically, there are two contenders for the job:
- Thermalright Silver Arrow SB-E Special Edition
- Prolimatech Megahalems Black Edition, 2x 140mm Prolimatech Red Vortex LED
Price is more or less the same. I like the cooling performance of the Silver Arrow, but figured that I can probably live with a 2-3 °K (if the reviews are correct) higher CPU temperature in exchange for a much less crowded interior and accessible RAM modules.
However, I found no documents on the Megahalems' compatibility with RAM modules and newer-than-Z68 motherboards, especially when paired with two 140mm fans.
Do you think the Megahalem will fit on the Gigabyte Z77X UP4 TH with 2 G.Skill Ares/Crucial Ballistix Smart Tracer modules in a Silverstone Fortress FT02?
One more thing:
Is thermal dissipation in the Megahalems' heat pipes an issue when installed in my Fortress FT02? Read something about some tower cooler having that problem...
