Thermalright Questions...
fuzzy34
Am I Really Still [H]ere?
Two questions....
Does it matter which way the SI-97 is mounted? Can the heatpipes be either to the left or to the right of the top of the socket?
Also, how is the difference in performance between the XP-90 and the XP120? I know the XP-120 will be quieter, but that's not important to me. I'm just wondering about the shear cooling performance gap.
Thanks.
1. Orientation doesn't matter, but the clip orientation does. I'll show ya how it works.
2. The XP-120 is much higher performing.
3. You suck, lol.
si-97 is only for socket 462
xp-90 and xp-120 is for p4s and a64s only
xp-120 if you dont want it quiet=200 cfm if you get that 60db delta if you want it quiet-ish its gonna be about 90cfm
