I'm looking at buying a Thermalright HR-05 IFX to cool the southbridge on my Asus Blitz Formula, but I'm not sure if I should get the SLI version. I want it to be compatible with two dual slot cards(such as the HD3870 X2) in crossfire if I decide to go that route. It -looks- to me that the SLI version wouldn't fit properly with two cards on my board, but I can't be sure. Does anyone know which I should get?
Also, because I'm removing the heatpipes from my board, I also have to cool the smaller Crosslinx chip with something. Does anyone know of a low profile(10mm or so) heatsink that's 25-31mm long on each side? It doesn't need any mounting holes or anything, as I'll be super gluing the corners(the board only has one mounting hole for the Crosslinx). I have this one right now, but I think it might be just a little too high.
