As I read it they tested AXP-100 with TY-100,120mm & TY-140mm fans; tested Samuel 17 with 120mm; and tested NH-L9i with NF-A9 & TY-100. The TY-100 is full speed at 2500rpm, 120mm is full speed at 1500rpm and TY-140 is full speed at 1300rpmWell you never know...they didnt show any results with the 140mm fan on full bore. I think it was only set to 1300 rpm to keep the noise down. An alternative that was suggested is the NT06-PRO but that wasnt tested or compared.
AXP-100, Samuel 17 and NH-L9i on Xeon E3-1230 v2 @ 3.49GHz; 19c ambient :
AXP-100 w/TY-100 @ 2500rpm = . 72.3c
AXP-100 w/TY-120 @ 1500rpm = . 72.4c
Samual 17 w/TY-120 @ 1500rpm = 77.2c
NH-L9i w/AF-A9 @ 2500rpm . .=. . 94.5c
NH-L9i w/TY-100 @ 2500rpm . =. . 85.5c
Actually using a duct from case to TY-100 on AXP-100 is a very good way to get cool air too or hot air away from the cooler.Fair enough. Ducts wouldnt be such a bad idea for tiny cases with relatively "bad" ariflow. You could use it as a heater in winter time![]()
