Thermalright 120 True question
mito
Will it fit in a 790i board? The northbridge fan is quite big.
What fan do you recommend with it?
Thanks.
I was owned... :)
What I really wanted to ask was if you guys had any problems trying to mount one 120 with the 790i.
Like any advice, etc...
Cheers.
Guess you obviously didn't read those threads as the first batch of posts say this:
It fits either way but is very tight vertically.
I had it in the vertical position and had to spend about 10 minutes frigging with the mount wires (there is only 2mm clearance where the nb is)
horizontally there is more room
Thread #2 even has a picture. http://www.ocforums.com/showpost.php?p=5655283&postcount=5
Amazing, did all your homework already and can't even bother to look at them.
