i have a Thermaltake Armor Series VA8000BWS
http://www.newegg.com/Product/Product.asp?Item=N82E16811133154
1) I removed the HD bay next to the psu, was this a good idea or should i put the HD bay back?
2) I put my HD, 250 gb 7200rpm, in the HD bay at the front. I put it in the middle secetion, will it be better in the top, middle, or bottom?
3) People who own this case will prob know this, in each driver bay cover there is little holes and then on the inside there is foam padding. should i remove the foam or keep it?
ps ever since i did this my cpu seemed to drop 2C and my gfx raised 3c, idel temps
