Hi,
Several months back I was putting in my aerogate 2 when I noticed in the instructions (yes I know I shouldn't have looked) that they recommend you mount the thermal sensor under the chip and route the wires between the prongs. At first I didn't do this since it didn't sound like a good idea. A while after this I was unhappy with my CPU temp as it was always at least 7 degrees C lower then the bios temp. I am going to be putting in a pelt setup and I am wondering if I should leave it in or remove it. I haven't heard of other people putting the sensor in this location but it may prevent the chip from seatting completely flat. Is there another location that people have used with good results that is not so obstructive? I am not having problems with it now but once I have the pelt installed I don't want to have to rip the setup apart a whole lot more.
