Feb 25, 2004 #1 D digiram [H]ard|Gawd Joined Nov 27, 2003 Messages 1,675 what can i use to get thermal compound off of my proc and hsf?
Feb 25, 2004 #2 T TruthInRuin Limp Gawd Joined Jan 14, 2004 Messages 286 I use Acetone, works great.. get a q-tip, get it a little wet with the actone and just rub it, then have a paper towel handy and just wipe it off. It might take a couple rounds of the above depending on how caked/baked on that paste is.
Feb 25, 2004 #3 F freeloader1969 2[H]4U Joined Dec 13, 2003 Messages 2,238 Use a q-tip to get the big stuff off. Then use a rubber eraser to take the rest off. Works like a charm.
Feb 27, 2004 #4 O OPUS1 [H]ard|Gawd Joined Apr 25, 2003 Messages 1,766 Use at least 90% isopropyl alcohol. Don't use an eraser! The eraser can leave micro particles that will negate the purpose of the thermal paste.
Feb 28, 2004 #6 D Duckzilla Limp Gawd Joined Dec 13, 2002 Messages 468 The folks at Artic Silver recommend using an eraser, but then they probably don't know much about thermal pastes.
Feb 29, 2004 #7 F FiZ [H]ard|Gawd Joined Dec 21, 2002 Messages 1,934 Rubber yes, any other type of eraser would leave residue.
