OldBuzzard
- Jun 6, 2004
Does thermal paste have a 'service life'?
My system has been running a bit warmer than usual lately, and I'm wondering if I should remove my waterblock, and re-apply the thermal paste? When I installed the waterblock, I used the paste that Koolance supplied.
My water level is good, and I've checked the radiator for dust, etc. and there is nothing out of the ordinary, other than the higher temps. No real difference in the ambient temperature or anything else like that either.
The CPU isn't getting 'that' warm (55C under 100% load), but it is higher than it used to be, and I tend to not like it when something 'abnormal' happens.
I've been using this EXOS for a number of years now (had it on my old 1.2 Athlon), and this is the first time I've seen something like this happen. I've tried to eliminate every cause that I can think of, and the thermal paste is the last thing that I can think of.
Any other ideas would help if anyone has them.
