Flogger23m
- Jun 19, 2009
A few months ago I had to work in my PC, so I removed my CPU's heat sink. When I was done, I put it back on without removing the old thermal paste and without applying more thermal paste (it has TX2 on it). Ever since I did that it seems like the CPU's fan spins at a higher RPM and the CPU seems to get hotter.
Should I remove the old thermal paste/grease and re-apply it? If so, what should I use to remove the old paste? And when reapplying should I do the drop or the X method?
CPU is an AMD 965 and cooler is a Xigmatek LOKI 92mm.
