I was wondering from anyone's experience, what do you find is the best way to remove Arctic Sliver 5 paste? I just build my rig and nothing displays or beeps, and I wanted to reinstall the cpu into another board to make sure its not the cpu. Does anyone have a way they think is good? I read that you should put some solution onto a q-tip and then dap it on a tissue paper and clean it that way. I plan to use Acetone to do it (found at Walmart in the painting section, it says it thins and strips). Would that be alright to use? And how long should I wait after placing acetone that I start cleaning, and how long should I wait before reinstalling and running?
