SilverChenbi
- Apr 29, 2012
So I tried googling this and I haven't been able to find a result so I thought I'd go ahead and ask the community. I've looked though previous generations of CPU dies and they have cores centered around the middle. Some examples and pictures are below:
Intel Gulftown:
Intel Nehalem:
Intel Sandybridge:
AMD Deneb:
So you've probably noticed that all the cores are usually centered for each die. However what did AMD and Intel do with their latest generation? Put the cores out on the edge.
AMD Bulldozer:
Intel Sandybridge-E
This lead me to speculate that the tradition pea size in the middle is no longer the best method for applying thermal paste. As I have a LGA 2011 chip, I will need a larger than pea size application to cover as much of the surface as possible. This doesn't apply to Ivybridge since they it looks almost similar to Sandybridge die. So now people of hardforums, how should we apply thermal paste to these two chips to make sure that the paste spreads over the highest heat generating areas of the cpu? I just thought of this as I was about to apply thermal paste to my new watercooling rig but now I want to test it out and I want to hear others opinions too! Should we apply two lines near the side for Sandybridge-E? Should we apply 4 small dots for the Bulldozers? I'll test it out and post it. Feel free to post your own results too.
Intel Gulftown:
Intel Nehalem:
Intel Sandybridge:
AMD Deneb:
AMD Bulldozer:
Intel Sandybridge-E
