Whisperfang
- Nov 12, 2007
How do i safely remove Arctic Silver 5 from the pins on my LGA socket? It's been pushed down in between several pins (dont ask).
find a very soft toothbrush (the box should say very fine or very soft bristles), dip it in 90% alcohol and slowly work your way through the pins...
Spray with some compressed air, then let dry for awhile.
mobo never even noticed that i stuck goo and a quetip in its socket......
I'm sorry, but I must, HOW did you do that exactly? Sorry for asking, but I dont want to make the same mistake?It's been pushed down in between several pins (dont ask).
I was thinking about compressed air as well. Then I thought maybe not, because the compressed air would probably drive any residue deeper into the socket.
I'm sorry, but I must, HOW did you do that exactly? Sorry for asking, but I dont want to make the same mistake?![]()
The compressed air was only recommended to be used after the heatsink compound had been dissolved out with the alcohol.
It is only used to facilitate a faster drying of the IPA.
My apologies for not making that more clear.
99% Isopropanol would be the best bet.It's safe for most electronics.Also , electronics degreaser would work as well (mostly iso) , and it's easy to use as it's in a spray can.
Also , yes Isopropanol will dissolve as5.
I would avoid actually touching the pins with anything , they are fragile beyond belief.
Because they probably assume your never going to let it get in the socket.I have arctic cleaning fluids, but none of their instructions say it's ok to put on the socket.
If you find Anhydrous Isopropyl Alcohol (You can buy it a huge ass bottle at Fry's for around $7) doesn't work on AS5, try Simple Green, diluted to a 3:1 ratio of Hot Water/Simple Green in a spray bottle. Then rinse the board in distilled water, and let it air dry out on the patio or something. I've had good luck removing nicotine and other nasties (including the Arctic Silver cleaning kit) from motherboards with that combo.
yeap, clean it with crc brake cleanIf you use Simple Green, brake cleaner, whatever - you can rinse with distilled water, THEN with isopropyl alcohol. Water and alcohol dissolve in each other, the alcohol will evaporate much faster (taking water with it) and make the process faster and more complete. You want to be sure any water in the tiny nooks and crannies of the socket is gone.
FYIMG Chemicals makes a huge line of purpose-specific cleaners, degreasers, contact cleaners and enhancers which are often at your local electronics supply store (NOT computer supplies, NOT chain stores). I use one of their zero-residue cleaner/degreasers and it's a great product. As I mentioned in a previous post, I feel this would be more effective than straight isopropyl alcohol.
