thermal pads for memory heatsinks
Forgiven
Where could I get some more of these?
I have a VF700 and put the memory heatsinks on and I am going to swap cards...where could I get some more of the pads?
Thanks
You can get them at quite a few places, just froogle them.
These right?
http://froogle.google.com/froogle_c...alman+ram+heatsink&lmode=online&sa=N&start=10
http://www.phatcom.net/shop/product_info.php?products_id=3921
http://www.newegg.com/Product/Product.asp?Item=N82E16835118220
I have those but they are now USED so do I need to get another thermal pad for the bottoms?
You might want to pick up some arctic silver alumina thermal epoxy. Getting new pads may be quite difficult. I know jab-tech has it in stock. Just dont mix it 1:1, and itll be a temporary bond which you can remove later (use less adhesive, more thermal paste)
