Help help help. I'm looking for a Thermal Interface Pad that's maybe 1/16" thick or 1/8" thick. I can't be conductive or capacitive. I'd like it to be tacky on both sides so I can use it as a thick frag tape so I can "tape" heatsinks on hot components. I'm thinking of using this to put a big but flat heatsink on the back of my videocard to help cool it off. If it works well I'll start using it to put heatsinks on the bottom of my hard drives and other equipment too. I'm currenly builing a low airflow quiet computer with only a 120mm fan for exhaust so I'd like to cooling everything as much as I can with gratuitously large heatsinks!
Do any thermal interface gel pads exists that could do this for me? I don't want to use thermal compound or the sorts because I don't want this to be a 100% do it and never go back application, if it's a tacky pad I'm assuming I can still peel it off somehow. And putting it on the back of a videocard, I'd like it to be removable. I once saw that koolance used some kind of gel that hardened to adhere their waterblocks to the bottom of hard drives and that it was still removable too, but I haven't been able to find out what it's made or find it on the website anymore.
Any help is appreciated.
