Thermal Grease/ stock HSF
Should i use the stock stuff that come with the HSF in box, or use some AS cearmique. Is there really a difference between the 2 or is one just as good as the other ?
Use the AS. I'm using stock stuff right now and my temps are quite a bit higher than normal.. (AS5 on the way...but shipping takes forever).
